Hi Team
Hi
when i execute the calculation process my web page automatically scroll down but i need to scroll up and then i need to take a full-screen screenshot too.
Please find the error screenshot too !!
Regards
RaviDevaraj
Hi Team
Hi
Regards
RaviDevaraj
Hi @arivu96 @Dominic @shankm @ovi
i tried the send hot key control in that i set the pageup so now i can able to capture the image.
This full screen i need to take a screenshot
but i cannot able to find i whole screen to capture i take screenshot control!!
i can able to capture like this only see below images !!
try to find out what mistake i have done ?
Regards
RaviDevaraj
@RaviDevaraj
click on the title bar of the browser, don’t care about the selection preview.
Modify its selector (it must contain the app name) ,try to remove all other unwanted things.
i think it’s already implemented on the importprocess.xaml which i have modified.
Hi @shankm
Yes, i found out in that control
I used it,now it is working fine as per my expectation.[Screenshot]
Thanks @shankm
Regards
RaviDevaraj.
Hi @shankm
For sending a mail i need to default message so for that i have used read text file control i typed the few lines of messages in notepad.
i wan to get as like this see below:
But i am getting as :
all line in same line itself "Hi Team,For the current month we are calculating the calculation plans.Please find the attachment of screenshot for current Period.*** This is an automatically generated email, please do not reply *** "
Like this
why ?
what i need to do?
Regards
RaviDevaraj
@RaviDevaraj
Are you using any mail activities to send mails??
@RaviDevaraj
If you are using send mail activities, there is an option called “isBodyHtml” in the properties pane. Tick it, and format your page using html tags and save it in notepad.
hi @shankm
need help from pdf to excel changing ?
from pdf file to excel converted done but the in excel file falling on data in one column itself (Like Column A)
can you Please help me out to overcome this issues ?
sample xaml file:
Main.xaml (13.8 KB)
my PDF File :
1090444_COMS_Commission Statement[1].PDF (148.3 KB)
my excel file[output file] in wrong format but data comes from pdf file it’s correct.
Untitled.xlsx (10.6 KB)
Regards
RaviDevaraj
Hi @shankm
Are you there ?
we can able to solve these issues ?
Regards
RaviDevaraj
hi @shankm
when I execute the file I am getting an error ? why ?
error message : execution start process failed. unauthorized Access Attempted : Access is denied
y what is the reason ?
@RaviDevaraj
That may be because of the user access level. Is your windows user have the administrator privileges?
Hi @shankm
Yes we have the administration previleges
Then why it’s showing an error message?
Regards
RaviDevaraj
@RaviDevaraj
can you open it manually ?
is there any UAC pop showing that time?
hi @shankm
see the error screen shot ?
see details error :
how to solve this issues in this program ?
