i was trying to install UiPath setup.msi going throufh advanced and selecting Robot to install. After clicking next iis setting appears there i had a a error with ssl certificate.
Hi, I’m not sure if you were able to resolve this error. I ran into a similar issue while installation. Make sure the following are checked:
- Host name is correct
- Host name should be the same as the certificate name
- Type the SSL certificate name, do not copy and paste.
- The SSL certificate should have the private key intact
- The certificate should be present in the Personal store
Can you please check these 2 posts
Regards
Balamurugan.S
