UIautomation and system acitivity dependencies Not fully Installed!
Is it possible to install UiPath studio-community edition in my worklaptop and a test box with my same email id? The idea is the code is my laptop, and have the code tested in the test env. If code changes are needed, I could do it in the test box itself. When i tried to install UiPath studio in the test box, the following dependencies did not get installed properly. Repair dependency is of no help either. This is the error message I am getting is given in the attachment.
The dependencies I need are also provided in the attachment.
What am i doing wrong? what are the steps I need to check to resolve this issue?
Any help is appreciated.
TIA.
-Daksha
I have similar experience with you.
For me, it just took so long time to install all the dependencies in need.
Is it still same?
@Daksha
Ideally using same id you cannot as it would be already tagged to the developer machine
And second are you getting any error? Generally first time it can take little time to install but it would install them
Alternately you can copy the packages folder in c:\users\username.nuget forlder and paste it in the same folder in test box ..that is where the packages are downloaded
The issue might be because of limited connectivity on test box as wel so check that also
Hi @Daksha
This might be temporary.
Try installing Windows updates and the latest .NET Framework versions.
Happy Automation
Yes, It did run for a long time, but didnt install properly. Tried more than once and the issue persists.
