Test Data Queue not mapping to more than 1 test case
Hi all,
We have a scenario where there are multiple test cases mapped to 1 test data queue. Whichever test case runs, it processes the test data from the queues. This has been working fine for us for quite some time.
However, of late it seems that only one test case runs maps with the test data queue and for the others only 1 record gets processed at a time. There is no error thrown during the mapping as well.
Example if I have 3 test cases - a,b and c, which uses a test data queue TDQ1. There are 10 test data items in TDQ1. Only 1 of the process will be able to utilize the 10 data items, while the remaining 2 will only process 1 item per run.
This seems to be a either a bug introduced in the last release or an intended feature. Can someone please help?
Thanks in advance
Nishant
Are you running it after publishing it to orchestrator or from the studio?
Hello
Running this from Orchestrator
Hello @Nishant_Banka1 ,
I cannot reproduce the mentioned behaviour.
In my case I am using a Test Set with 3 different TCs which all use the same TDQ.
When I execute the TS, all variations for all TCs are executed properly.
Can you share the Studio and OR version you are using?
Additionally can you probably share a simplified Studio project that reproduces the behaviour as well as a download of your Test DAta Queue?
thx in advance
