I download a Tableau Crosstab and tried both Today.tostring(“yyyy-MM-dd”) and Today.AddDays(0).tostring(“yyyy-MM-dd”), to see if that might be the issue, but it didn’t work.
I added delays between downloading and reading, but that too didn’t work.
All my folders on Orchestrator are linked to the unattended bot,
and one can see if I trigger the bot manually via Assistant directly after publishing, it works,
but then it does not work when the Time trigger activates the process.
Then Manually triggering the bot on Assistant fails again.
I ran out of Ideas, any help would be great, thank you.
