Studio Design Canvas for State Machines too small
I’m finding that the designer canvas for State Machines is way too small to work effectively. I constantly have to scroll up or sideways to see the flow. This is very tedious and time consuming. There should be a way to make it full screen quickly, so you can click on where you want to zoom back in.
@Terry_Marr
you have the overview panel which can actually help for quicker navigation…I understand you wanted somethign liek a double click zoom and this can be as close as that
cheers
Hi @Terry_Marr , just to confirm, are you looking for Fit to screen functionality or something like a full screen?
Hi @Terry_Marr ,
There is an option that you can use called Fit to screen. Right now, it requires an extra click to adjust it better to the screen and we’re working on addressing this.
Would there be a different capability you are interested in?
Thanks @Raluca_Laic to share this option.
