Hi ,Consider the following case,
Case 1:
<html>
<div class='parent'>
<data>"Content X"</data>
<data>"result1"</data>
<data>"Content Y"</data>
</div>
</html>
Is there any possibility to frame a selector to check the existence of the element(result1) that is
next to Content Y and not the one after Content X using nav tag or any other options.Since both
the elements have same aaname i’m facing issue in framing selectors.Also the following cases
are also possible even then i need to check only the existence of result1 that is next to Content Y
Case 2:
<html>
</div>
</html>
Case 3:
<html>
</div>
</html>
