I want to read specific information from Outlook mails with the Matches activity. I know that the match is working and I want to get that exact information from the mail and save it in a variable after the match to further work with this info. I used an Assign activity and tried with [name of the matches result].toString but what I get is some cryptic info: (System.Linq.Enumerable+d__97`1[System.Text.RegularExpressions.Match])
Is there a possibility to get the info as a string?
yah thats possible buddy
you are almost done
–inside the for each loop next to this matches activity use FOR EACH activity and pass the output variable obtained from matches activity and change the type argument as system.text.regularexpressions.regex.match and change the variable name from item to match
–use a writeline activity like this match.ToString
where match is the variable from for each
Hey @Palaniyappan,
I don’t quite get your solution, I’m afraid. I should put another for each in the existing for each?
And what activity should I use for passing the variable? Assign?
Could you please clarify - I am a little lost
Yes
The sequence would be like this
For each
Matches
For each
Writeline // this will display each value from matches activity
assign
So the sequence would be like this
—inside the current for each loop next to this matches activity use another FOR EACH activity and pass the output variable obtained from matches activity and change the type argument as system.text.regularexpressions.regex.match and change the variable name from item to match
