i am building a project where I need to replace the data from excel file to word document using replace text activity. The issue is that the activity could not capture the word, how to correct it?
as per error the input search word you provided or the variable you provided is empty or null..please check the same
cheers
please check the values of str_name and str_individual from locals panel ..while running in debug
cheers
try hardcoding the values first (like “oldWord” and “newWord”) to see if it works, then switch to variables. if still error, please share your activity property screenshots.
Happy Automation
thanks for your help
yes it is resolved. Thanks
