Just a question…has anyone run into this? I have this on two different automations. Both use the same activity package versions. One automation I have no issues with. The second automation I get the following “Compiler error(s)…Text is not a member of string.”
In both automations System.Text.RegularExpressions is in imports. If I use just Regex.Match and the expression the automation only hits on a portion of the sample set even though a regex test matches all files in the sample set…Thoughts?
My guess is that you have a variable called system of type string. Rename that variable to something else, e.g. system1 and it should solve your issue.
I thought of that and there is no other variable with system. I am doing a code review on this one from another developer and I cannot figure this one out. I will send it back to him to use the matches activity and iterate through the table. Thanks though!
Ok, that’s weird. There should be no difference between System.Text.RegularExpressions.Regex.Match() and Regex.Match() since they both refer to the same function.
