I check whether the “description” string variable holds a certain keyword.
Now my question is can I use wildcard like “report* sheet” so it will return true if the description is “reported sheet”. Or is there anyway i can make it work.
Yes, it returns true, however * does not mean wildcard in regex. For example,it also returns true if input string is “repor sheet”.
Can you try the following expression?
