This is something I am having a problem with currently that I can’t seem to find a lot of training on.
Inside of my GetTransactionData I am using TryCatch blocks and I am seeing the logs come through when there are catches, however it is heading to the Process block instead of the End block. I do not understand this well enough to see what the problem is here.
The SystemError variable should be assigned exception in the Catch, so that when the condition is looked, SystemError will not be Nothing and go to End Process.
