Problem with Path Exists
Hello all,
I would like to check whether a file exists, but this does not work.
The initial situation is the following Multiple Assign
File_Path= Directory.GetFiles(ExcelPath)
FileName_Array={“_3898.xlsx”,“_5058.xlsx”,“_6518.xlsx”}
filtered_Files=File_Path.Where(Function (x) FileName_Array.Any(Function (f) x.Contains(f))).toArray
File=0
The Path Exists activity says “File_Path.Where(Function (x) FileName_Array.Any(Function (f) x.Contains(f)))(File)”.
I query this value in a Flow Decision and always get the value “True” even though this file does not exist.
What am I doing wrong?
based on your variables from above
assuming we want to filter the retrieved Paths on filenames contained within the FileName_Array items we can do
Assign activity
LHS: FilePathsFiltered | String() - string array
RHS:
File_Paths.Where(Function (x) FileName_Array.Any(Function (f) x.toUpper.EndsWith(f.toUpper))).toArray
Thank you, the main problem was the read range activity. In the table, an entry was marked in colour and caused the error.
