I have a virtual machine where the assistant works.
Last week I had a problem and I had to restore the PC to an earlier point.
The problem that I have right now is very extrange because the assistant sometimes it’s connected to the orchestator and sometimes not, becuase the green light appears in red and I have to press the update boton to reconnect.
I tried to reconnect with the same account but the problem stills.
I don’t understand why is connected with the green light and suddenly appers in red, then in green, then in red…
No, the execution are not affected because it’s like a bug and yes I tried to reconnect again with the same account. I think the problem it’s a token or something like that , because this problem appears after the restoration point.
I dont’t know but it’s strange because it’s connected and then disconnected, but when it’s disconnected if an RPA is in execution doesn’t get affected, so it’s very extrange.
