I am automating a process which has citrix automation. Now there might be a situation where a pop up may come up and I don’t know when this pop may come up. Due to this pop up a exception might occur and now I want to handle this exception. The only way of handling this exception is closing the application. since this is a citrix automation I can’t use kill Process. How can I handle this.
Hi
keep the whole process inside the TRY block of TRY CATCH activity
so that if any exception occurs it will go to CATCH block where we can have a SEND HOT KEY Activity with key as alt+F4
Cheers @Shashi123
