Hi Everyone, I hope you doing well!
I am facing a challenge while trying to split a variable named ‘StrExctractedText ’ into an Array by splitting it with a newLine delimiter
that contains the following text:
I tried to use the split function but the result after Looping inside the Array is a single-element array instead of three elements as expected. as you see here:
After several tries, I changed the way to Regex, here:
and the output is a 5 Elements array instead of three elements also
Can anyone provide guidance on how to correctly split the ‘StrExctractedText’ variable into an array where each line is a separate element?
ppr
(Peter Preuss)
January 9, 2024, 8:49pm
2
give a try at trimming
Assign Activity:
arrSplits | String Array =
YourTextVar.Split({Environment.NewLine},StringSplitOptions.RemoveEmptyEntries).Select(Function (x) x.Trim())
You can prototype it within the immediate panel as well
Yoichi
(Yoichi)
January 9, 2024, 11:42pm
3
Another approach:
It may be linebreak matter. Can you try the following expression?
StrExctractedText.Split(vbcrlf.ToCharArray,StringSplitOptions.RemoveEmptyEntries)
If you need to trim each item, @ppr 's LINQ expression will help you.
Parvathy
(PS Parvathy)
January 10, 2024, 12:44am
4
Hi @Islam_ISmail
Try the below following way:
StrExctractedText= "Client ID: BL17488
Client Name: Mabel Suttle
Client Country: Romania"
arrDetails= StrExctractedText.Split({Environment.NewLine}, StringSplitOptions.RemoveEmptyEntries)
Hope it helps!!
SplitAndTrim.zip (2.7 KB)
Use this Workflow
postwick
(Paul Ostwick)
January 10, 2024, 6:43pm
6
Use Split(yourstring,delimiter) instead of yourstring.Split because the former accepts a string instead of character array.
Thank you for your response that helps me!
ppr
(Peter Preuss)
January 10, 2024, 6:54pm
8
@Islam_ISmail
Perfect, so the topic can be closed
Forum FAQ - How to mark a post as a solution
This document is part of our beginners guide .
This article will teach you how to properly mark a post as a solution.
We were closely following our last UiPath Forum feedback round! topic and carefully extracted all the bits of feedback that was provided. As such, we would like to tackle the topic of solutions on our Forum and how to properly use them.
When is the topic resolved?
The topic can be considered resolved when the topic author has found…
Thank you for your response I’ll try this out !
Thank you for helping me out !!
system
(system)
Closed
January 13, 2024, 6:56pm
11
