I have a problem with a specific powerpoint task. I would like to create a workflow with a power point presentation as a template. Then slides with a specific text field (e.g. Group 1) should be copied from the template and should be pasted into another (new) presentation. So far I could build the workflow with the numbers of the slides, but not with a text field on the slides.
Hi @LiMa,
Welcome to the Community!
To be honest this sound for me like you rather should use Mailings function built in for each MS application.
Hello Lima,
In this video, I have multiple use cases of UiPath working with POWERPOINT via VB.NET:
1:10 Install NuGet Package for automation
4:00 Use-Case 1 Add a new slide and add a picture
8:20 Add Chart
10:35 Add a text with shadow
12:30 Perform a slideshow
15:00 Delete slide and Export to PDF
17:30 Working with comments (Add, Read, Delete)
19:50 Create a complex PowerPoint from 0
Code:
Thanks,
Cristian Negulescu
