I am trying to connect to by Oracle DB. i saw lot of post about the same. However am not able to connect. Kindly help with the same. It will be helpful if we have document on the same.
Am using Microsoft ODBC Data Source (ODBC)
In driver: “driver={Microsoft ODBC for Oracle};server=xxxx;uid=xxx; pwd=xxx"
getting Error IM002. Datasource Name not found.
Kindly help. We have lot of Oracle DB automation on hold.
My IT department deals with this.
All I can tell you is that you need to install on a machine (dev, robot) ODBC driver that will be compatible with the Oracle database version on the database server.
The rest of the setup steps are to go through my question list from the previous post:
ODBC Driver + Oracle Instant Client
Create DSN user and configure connection
Create environment variables
Add tnsnames.ora with configuration in: C:\app\product\11.2.0\client_1\network\admin
Install UiPath.Database.Activities in Robot Project
