Not able to load "SentenceTransformer" package in python script
Only when “SentenceTransformer” (NLP based python library) imported in the python script and executed, I’m getting below error while execution.
Note: Installed “SentenceTransformer” library in the python execution environment imported in Uipath.
Otherwise the same code is working fine in the command prompt outside Uipath.
RemoteException wrapping System.AggregateException: One or more errors occurred. —> RemoteException wrapping System.InvalidOperationException: Error invoking Python method —> RemoteException wrapping System.IO.IOException: Pipe is broken.
at System.IO.Pipes.PipeStream.CheckWriteOperations()
at System.IO.Pipes.PipeStream.Flush()
at System.IO.StreamWriter.Flush(Boolean flushStream,
Boolean flushEncoder)
at System.IO.StreamWriter.Dispose(Boolean disposing)
at System.IO.TextWriter.Dispose()
at UiPath.Python.Service.PythonProxy.RequestAsync(PythonRequest request,
CancellationToken ct)
at UiPath.Python.Service.PythonProxy.InvokeMethod(Guid instance,
String method,
IEnumerable1 args) at UiPath.Python.Impl.OutOfProcessEngine.<>c__DisplayClass14_0.<InvokeMethod>b__0() at System.Threading.Tasks.Task1.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at UiPath.Python.Activities.InvokeMethod.d__16.MoveNext()
— End of inner exception stack trace —
at UiPath.Shared.Activities.AsyncTaskCodeActivity.EndExecute(AsyncCodeActivityContext context,
IAsyncResult result)
at System.Activities.AsyncCodeActivity.System.Activities.IAsyncCodeActivity.FinishExecution(AsyncCodeActivityContext context,
at System.Activities.AsyncCodeActivity.CompleteAsyncCodeActivityData.CompleteAsyncCodeActivityWorkItem.Execute(ActivityExecutor executor,
BookmarkManager bookmarkManager)
Hello @MAHALAKSHMI_S!
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
  1. Always search first. It is the best way to quickly find your answer. Check out the image icon for that.
    Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
  2. Topic that contains most common solutions with example project files can be found here.
  3. Read our official documentation where you can find a lot of information and instructions about each of our products:
  4. Watch the videos on our official YouTube channel for more visual tutorials.
  5. Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
Cheers from your friendly
Forum_Staff
@MAHALAKSHMI_S any solution for this?
Hi @Atul_Rai , UiPath does not support loading some advanced python libraries like SentenceTransformers.
Instead of integrating the python script via Python scope in UiPath, you can call the script via powershell command.
Thank you so much @MAHALAKSHMI_S
I wasted my one week but thought the same solution you suggested.
One strange observation is that it is working in other machine but not at my machine.
