I’m unable to find the option to create robot in orchestrator in new update.How can I solve this problem
Hi @shreyasingh
Try clicking on Orchestrator Icon on the left hand side, then the top menu bar there will be a Robots option and then a blue button on the right will appear “Add Robot”.
Please see the screenshot I’ve added.
Hey, are you able to solve this issue ?
@shreyasingh
From the looks of your picture you have the Tenant selected, try clicking on one of your folders depending on which one you would like to allocate the robot to.
I’ve highlighted the area with a red box, after selecting the folder it may reset your selection so you may need to click on Robots again in the top menu bar.
