Nested for each loop to read rows and column in excel sheet
Hi
i need some help over here to read each row value and column to be copied over to a original list of excel sheet.
example, i would need to copy values from B2:E9 based on the screenshots and each row going to copy and paste into a file that holds monthly original list… meaning i would received a daily report in excel A file consisting of header 1 to 4 values and i would like to make the UiPath to copy and paste the daily report to a original listing which going to compound into monthly listing.
however, based on my flow i only managed to get the first row value and the flows stopped and it does not copied over to the original list and to move to the next row(completed row B but not moving to row C and closed the flows)
Hello @Waka
Can you show raw data of excel and Result excel that you expected it to be?
Best Regard,
@NutchanonSwnl
im trying to use the nested for loop to copy and paste the value from Daily report to Monthly report
Screenshot 1
screenshot 2
@Waka
Instead of Creating a new variable ColCounter for incrementing you can declare a variable in For Each row properties Index, that will act as your Counter
Hope this may help you
Thanks,
Srini
Hi @Waka ,
You can use the merge datatable activity to append your daily report datatable to make monthly report and then write it to the excel.
regards,
In case if header name from DailyReport and MonthlyReport are same
you can use append activity like this
DailyReport Data:
DailyReport.xlsx (8.9 KB)
MonthlyReport Data:
MonthlyReportBefore.xlsx (8.9 KB)
Result after using flow
MonthlyReport.xlsx (9.2 KB)
Hope this one help you but if it’s not the same header name we can discuss about this later
@Srini84
may i know how does the properties index works?
@NutchanonSwnl
the headers are the same in both files, however the daily report rows is dynamic and it could in range from 5-20 rows in the daily report. can the append range work for this ? i tested at my file and the cell range is hard coded.
When you use Read Range you can set like this
Change “Sheet1” into your sheet name but leave Range(“”) to be the same
it will read all column and row and save to DailyReportData
then we use append to set all row of Daily Report into monthly Report by next available slot
Best Regard,
Hi @NutchanonSwnl
i can’t use range(“”) and would need to specific the range because it will append other things liner or words into the monthly report.
In your Daily Report Template does it have decoration text below after lastrow of data?
If not you can write like this (For example Specific column of data is A to D)
What i mean is something like this
Best Regard,
@NutchanonSwnl
yes, my excel file have decoration text at the first and last row.
when i use the read.range(“A1:D”)
there is an error message showed "Could not read range A1:D
Workflows :
FlowForWaka.zip (31.2 KB)
Assume that your daily report is having first 3 row as decorate
and last 2 row as decorate like this
after use this workflow will process excel into this
then we use append as normal to end our flow
Ref:
for description each activity will be like this
Hope this one help
Best Regard,
Hi @NutchanonSwnl
i follow your code and use it on my script, the code giving me this error showing “Invoke Code:Exception has been thrown by the target of an invocation.”
while i run your example shared with me, and i dont have this error message
any possible solution for this?
Hi @vishal.kp
Does this merge datatable remove the header from the daily report and merge the data to monthly report?
Hello @Waka
Could you check at edit arguments? might be missing with arguments or variable
Some screenshot would be nice also.
Best Regard,
@NutchanonSwnl
i followed your code or i could i missed it some where
@Waka
TodayDT might not get a correct type of data or maybe inside of invoke code is not right
Can you debug and check if it pass ‘TodayDT’ datatype or data to invoke code correctly or not?
Best Regard,
@NutchanonSwnl
TodayDT datatype is “DataTable”
May i know how to interpret this line of code?
First we read range into “DT_Daily”(assume this is my workflow) then .AsEnum.skip will skip first 3 row(work like delete first 3 row) then copy to “DT_Daily” as datatable(Just like after modify data we copy into same variable datatable)
if you have change your variable name into TodayDT please also change “DT_Daily” to “TodayDT”
Just like this
TodayDT.AsEnumerable().Skip(3).CopyToDataTable()
Best Regard,
