Need help with Find Element
I’m trying to find the All Access Objects button that is displayed in ACCESS after running a Compact and Repair. I don’t won’t The Robot to close ACCESS until the Compact and Repair is complete. But the Find Element is not waiting. I have wait till visible checked. Should I be setting another property or try using something else?
Hi @robert.clark.53 ,
Slightly off topic, but if you were to use the Check App State Activity, it allows you to wait for an element to disappear, if that is what you were aiming for->
If that doesn’t work, then you might have to use the Wait along with a static delay.
Kind Regards,
Ashwin A.K
Thanks I will try. Building my first Robot. I’ll probably never place in correct topic.
Hi @robert.clark.53
Welcome to community
Have a look on the workflow
FindElementWait.xaml (7.7 KB)
In The Flow decision
FindEleVal.ToString.Contains("Value here need to find")
Regards
Gokul
@robert.clark.53 It looks like you are keeping the find element before running a compact and repair. Why don’t you use it once the compact and repair completes. Also, you can use element exists to find the element present or not
