Hi UiPathers,
I want to see if I can get some input/suggestions on how I would build the following:
Request:
I need to build a workflow for the bot to run on specific days. Here are the following scenarios:
- Bot will run every Friday
- Bot will run on the 15th or the last day of the month (the last day varies from month to month)
This is my logic behind the bot:
IF Today’s Date <=15th
Then
start date equal first of the month and end date equal 15th
IF Todays Date >15th & <= 31st
Then
start date equal 16th and end date equal 31st
IF Today = Friday
then
start date equal today - 4 days and end date equals today
Is the best route to take to use an If/Then Condition?
Is there a way to integrate a calendar to make this process easier?
any additional tips for building the workflow? Is any additional information needed to clarify?
