Hello All,
In queue based trigger for each new queue item we create or try to create a new job and the minimum limit for “Maximum number of pending and running jobs allowed simultaneously” could be set is 1.
I am looking for a way to not to create a job for new queue items that appear during runtime. Is that possible?
Alternately, is it possible to process only one queue item per job created, that is the queue item that triggered the job will process only that one and not any other queue item even if they are in new state. This will be solved if I connect process to end state but is there any other way to do this if it is a need to use RE framework only?
