Level 3 Assignment1 - Need help with pg.13
Hi All,
I need help with the below. I have created my out arguments, but I am unclear of what the vb expression should be. What am I not understanding?
thanks!
@jonathan89
Try this:
Use Get Text to get client data into ‘ClientInformation’ variable.
out_ClientID = ClientInformation.Substring(ClientInformation.IndexOf("Client ID: ")+"Client ID: ".Length).Split(Environment.NewLine.ToCharArray)(0)
out_ClientName= ClientInformation.Substring(ClientInformation.IndexOf("Client Name: ")+"Client Name: ".Length).Split(Environment.NewLine.ToCharArray)(0)
out_ClientCountry= ClientInformation.Substring(ClientInformation.IndexOf("Client Country: ")+"Client Country: ".Length).Split(Environment.NewLine.ToCharArray)(0)
Out_ClientCountry =Out_ClientCountry.TrimEnd.TrimStart
try with this
thanks, but it appears with an error.
Is it something that I am doing wrong?
This method does not give me an error. I’ll try running the process, and see if this works.
Thanks for the suggestion.
@jonathan89
On right hand side, remove that out_ClientID = and Write below one:
Perfect. This worked.
Thanks!
