Issues with sharepoint read range using url
Hello
I am having a strange issue with integration service read range activity using the file url
When i do it on studio the robot finds and reads the file with no issue
On unattended with the exact same parameters it throws a “resource not found” error
Check that SharePoint access to the that systems.
pls check below point hope this will help you
Unattended Robot Service Account Permissions: Double-check that the unattended robot service account has the necessary permissions (read access) to the file URL you’re referencing. Ensure the file path translates correctly to the unattended robot’s execution environment.
Execution Mode: Make sure the unattended robot is configured to run in unattended mode. Studio mode interacts with the user’s session and may not function as expected in unattended execution.
