I am trying to send a UiPath http post request with json body, i am getting the status code as 200, but the problem is that data is not reflecting to the end point. And the same is working perfectly with the postman.
This is the original Json Data with postman.
“works”: [
“externalId”: “21999333”,
“workSpecExternalId”: “7754”,
“ff_Work_Name”: “Test Postman”,
“ff_Employee”: “211”,
“ff_Crown_Paints_Entity”: “A”,
“ff_Supplier_Name”: “Crown”,
“ff_Supplier_Number”: “07654”,
“ff_Supplier_Deliver_Note_Number”: “777432”,
“ff_Truck_Number”: “Ap06Kenya”,
“ff_Supplier_PO_Number”: “6000”
This what i am trying to provide while with uipath.
I don’t understand the issue. Both json bodies are the same structure and they both have status code 200. Are you confident the issue is UiPath? I would expect a different status code if there was an issue with your UiPath post call. Could you please provide more detail about what you mean by:
Hi @zwils0, I understand your concern but the same thing is working while i am sending through the postman, and with uipath getting status code as 200 but it is not reflecting the data to the end point.
