Hello is anyone interested in helping me with this.
If you are let me know I can send you the zip file.
Task:
Each day you are required to mark the attendance of network technicians. Given the “attendance.xlsx” and “attendance.html” files, automate the steps of marking of attendance on “attendance.html” based on the data in “attendance.xlsx”. Refer to Figure 2 and Figure 3.
Hello @Kristopher so sorry to trouble you again could you send me a screenshot of the two parts where you need to indicate the radio buttons for late for and the last part absent etc.
If you change the browser to Google Chrome, some of the selectors may change. You will need to adjust the dynamic selectors to fit your environment since the selectors I chose for Edge do not seem to be working in your environment.
I am guessing, but you probably need to rename the files being manipulated since they do not match the example.
attendance (1).html → attendance.html
Attendance.xlsx → attendance.xlsx
