Hey guys,
I need to read the numbers on image and do the x+y problem and write the answer to box. This is security test that changing every time. Can you help me on that.
Im leaving another examples down, so you can try.
It is intended that you do not automated this. If you try, your process will break soon, because Captcha may change to another type.
Yes but to finish my project I need to pass this security step somehow
As Thomas said, these are specifically designed so you can’t solve them with a bot. The lines over the letters make OCR not work.
There are paid services that allow you to complete security checks like this. Here’s one example.
Ok. Thank you
thx for answer
