I need help with an automation
Can someone help me with looking throught my automation and tell me what is wrong? I need someone who can tell me in an app, thank you!
Hi @Cristian_Lighezan
You can share your problems what you are facing in your automation here with some data or a screenshots then we are able to understand it and give you the solution.
Hope you understand!!
@Cristian_Lighezan Can you share the exact problems here?
Hello,
I will attach my main.xaml, i try to make a process that automation my work, but it wont work, i try to automate the extract of pdf file, then read the total from them and tried to put them in an excel, and this is the error that give me, thx
În dum., 8 iun. 2025 la 07:30, Darshan Sable via UiPath Community Forum <notifications@uipath.discoursemail.com> a scris:
(attachments)
Main.xaml (28.2 KB)
Hello,
În dum., 8 iun. 2025 la 02:20, Mahesh Kankatala via UiPath Community Forum <notifications@uipath.discoursemail.com> a scris:
@Cristian_Lighezan I see you are using desktop outlook activities, make sure you have outlook installed.
If its already installed try upgrading UiPath.system.actvities and outlook activities package
I upgraded the
But outlook activities says that is not compatibile with windows projects
În dum., 8 iun. 2025 la 14:04 Darshan Sable via UiPath Community Forum <notifications@uipath.discoursemail.com> a scris:
@Cristian_Lighezan is outlook installed on your machine?
