Click on Generate Coded test case
I Want Generate Code with Autopilot Options
This option Generate Coded test case
generates the test case using autopilot isn’t it?
test case generate but I want script
Can you elaborate more on what script you are expecting?
I am getting Autopilot option for generating Scripts
if you are talking about generating on coded flow then the below highlighted option would help
cheers
For that make sure your Studio version is >= 2024.10
@ashokkarale thank you
Kindly close the thread by marking the answer as solution
the version needs to be higher and also once you click on a line or so you get the option
cheers
