How To Split symbols and write into separate column/row?
Dear All,
Possible if i have a scenario for where i want to to split the symbols and write into new columns like below
Before
After split it should look like this
Test Example.xlsx (16.6 KB)
i tried several features like excel application scope>split string>for each>write line
or text to columns.
Need your expertise to advise which are the most simple feature/expression editor code, and way to achieve this.
Hope the following sample helps you.
FOrEachRow case
LINQ case
Sample20221114-4 (2).zip (20.1 KB)
Hi @Yoichi ,
It works perfectly!!
Thank you so much for help!!
