How to split and read first character of string
I have a task to query a telephone number from my database. The result of the database query is varied. Here are some example :
+621234561412, 01251265236, 62124162316326, +6251325235213
62123445432, 01256236432
01232115156, +62163434636
8913214214
The goal is :
  1. I have to output the first 3 phone number in 3 different column in excel format. So if there are 5 phone number, I just have to take first 3. The phone number separator in my database is using comma (,)
  2. The phone number output must be 62, not +62 or 0 or without 62. Every phone number MUST have 62 in the front of it.
I tried to use StartsWith and Remove but somehow it’s not working. Any idea for this case? Thanks :slight_smile:
Hi @Rhys18 ,
Could you let us know if the data is contained in a Datatable format or String format ? Or is it already present in the array format?
Also Could you show us How you have performed this implementation ?
The data is presented in string format. I queried then I use for each row activity and I got in in string.
So if I write the data table, it will write to the excel like the example I give to you. It’s not in Array format, just simple write datatable
Sure, this is how I do it
Note : No_hp = phone number
@Rhys18 ,
Considering the conditions mentioned, from the String data provided, How would you Output it to excel and which would be the 3 values that you would choose if done manually ?
Ok, I assume you still confuse about the output. Here’s the expected output :
@Rhys18 ,
Could you check with the below Expression :
Let str be the string variable which contains the data, then we can perform a split based on comma and convert it to an array of String. We can then perform a modification on the values as per the conditions and then select the modified values as the new set of values.
str = "+621234561412, 01251265236, 62124162316326, +6251325235213, 8913214214"
First3Values = Split(str,",").Select(Function(x)if(x.Trim.Trim("+".ToCharArray).StartsWith("62"),x.Trim.Trim("+".ToCharArray),"62"+x.Trim.Trim("+".ToCharArray).TrimStart("0".ToCharArray))).Take(3).ToArray
Here First3Values is a variable of type Array of String.
You should be able to use this array value as the input to the Add Data Row Activity
Immediate Panel View :
This is the output :
@Rhys18 , Could you show me your Add Data Row Activity Properties or the value that is being passed ?
Did I do it wrong?
@Rhys18 ,
Try Specifying just no_hp do not add the brackets
Ok it’s working as expected! Thank you Mr. Arpan :smiley:
