Hello everyone. Does anyone know how to resubmit the projects for the Advanced Dev certification? I reset the ACME test data before submitting and now I’m stuck in limbo and it will not let me move on to the next project.
I’ve since ran the workflow again in an attempt to fix the problem and all my test cases pass, but UiPath academy will still not let me move on. I’ve also tried logging out and back in. I believe I need to delete my current submission and resubmit the project but I don’t know how and there is no third tab for resubmission.
Any advice would be appreciated. Please see attached screenshots of my current situation.
@victorjb Did it actually solve your issue? I have the same issue and UIPath support also deleted my submitted file so I could upload again. After re-submitting my solution I’m back at square 1. No Results tab and my uploaded file is not evaluated at all.
I spoke too soon. You are correct. I too am back at square one. UiPath support deleted my submission so I could reupload and I still have no grade and no ability to move to the next section or delete my submission.
These were the steps I took, let me know if you did the same:
Reset test data → Ran hash program(which successfully completed all WI5 tasks) → Zipped and submitted entire has project to academy
I just re-submitted the zip-file since the instructions stated that you shouldn’t reset the data until the evaluation is done. But the issue is the same. Stuck at submitted and no Results tab. There’re several other users having the same issue from what I can see in this forum. I wrote to the UIPath support again last Monday (21 Sept) and explained to them why I believe it’s a platform issue and not a user error. So far I have not received any reply from them.
