As shown in the figure below, I received the following error message when trying to connect to test manager from studio pro.
How can I solve this problem?
error message: How to resolve SSL/TLS connection errors when connecting to test manager from studio pro
details: System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
※I think the test manager that I installed is already working.
thank you for your quick replay.
It seems like the remote certificate is invalid.
I also got this information in deatils.
Give it a try to access the URL using browser (IE etc). Probably we can know its cause such as date expired, hostname is not matched with cn in cretificate, not trusted certificate or chain etc.
This means the server certificate isn’t on your trust certificate chain.
Do you have root certificate of the server certificate? Probably you need to add the root certificate to your certificate store of OS.
