How to perform a CTRL+Click(mouse click operation)?
Hi All,
I have to mimic a human operation by clicking CTRL key in the keyboard & do a click operation in the mouse at a time, Can anyone suggest a possible way?
Thanks,
Venkatesh.
@Venkatesh_Prasath,
yes it is not working for me…
I am still trying… to find… team thoughts are welcome on the same…
@rkelchuri,
In Your Workflow, they run in Sequence order.
Which means, Once the Send Hotkey Activity is completed then run the Click activity…
Then how can it Possible.
Yes…That will not work! Any other suggestion??
Set the Key Modifiers in Click Activity.
It is not working…anyother go? Like i have to select some of 2-3 values from a drop down box by clicking left mouse button with the help of pressing control key…
