Hello community,
I want to insert my own variable value in a specific xml attribute for an activity (inside the edit selector).
Can anyone help me on this?
Thanks,
John
Hello community,
Thanks,
John
Thanks for your reply. I tried that but it throws an error
Compiler error(s)
Option Strict On prohibits operands on type Object for operator β+β
Hi John_D,
Please find the below attached images for insert a variable in selector for click activity.
1.within the single quote type Ctrl +Space you can able to see the variables.
2. select variable which you need to insert variable and click on ok button.
Thanks,
Neelima.
Thanks a lot. Yes, ctrl+space brought the variables inside.
I would like to ask one more thing, what if this activity is inside a βForEachβ and I try to use the βitemβ variable inside.
Any suggestion on this case?
@John_D In that case can you just try and check just by using aaname=β{{item}}β but make sure the variable item is of type String else you would need to convert it to a String and store it in another variable and use that variable. I am not sure if the selectors support Object variables better to convert to String.
