Please suggest how to create shortcut or desktop shortcut to run automation.
Try searching the forum for how to start processes from the command line. From there it is easy to create a shortcut that runs the command, or references a script.
I’m afraid to inform you that, It’s not available.
Workaround would be…
- From UiPath Studio
- From UiPath Robot Agent
- From command line
- Through a REST command
- Orchestrator
