Please help?
you can follow these steps:
- Install the necessary dependencies:
- Make sure you have the Oracle Database client installed on the machine where UiPath is running. This client includes the necessary drivers to connect to the Oracle database.
- Install the UiPath.Database.Activities package in UiPath Studio. This package provides activities for interacting with databases, including Oracle.
Drag and drop the “Connect” activity from the UiPath.Database.Activities package onto the workflow canvas.
In the properties panel of the Connect activity, configure the following:
- ProviderName: Set this to “System.Data.OracleClient” or “Oracle.DataAccess.Client” depending on the Oracle client version you have installed.
- ConnectionString: Set the connection string for your Oracle database. The connection string should include information such as the server address, port number, database name, username, and password.
Here’s an example connection string:
"Data Source=(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=server_address)(PORT=port_number))(CONNECT_DATA=(SERVICE_NAME=database_name)));User Id=username;Password=password;"
Replace the following placeholders:
server_addresswith the IP address or hostname of the Oracle database server. -
port_numberwith the port number used for Oracle database connections (default is 1521). -
database_namewith the name of the Oracle database. -
usernamewith the username to connect to the database. -
passwordwith the corresponding password. - Click on test Connection.
Hope it will helps you
Regards
Gokul
tried but tcp transport address connect failure error coming.How to fix that
Can you share the screenshot of the error?
If I select Oracle.ManagedDataAccess then I am getting error like this
If I click ok & select Oracle.ManagedDataAccess then screen is like this
By downgrading database.activities to 1.6.1 it works.
In run query step even though I pass query in double quotes again it is asking double quotes expected error. Some alias names are there in query will that cause error?If I remove alias names error is gone.Will that possible with alias names?
Please help?
