Hey guys.
I need to capture a specific one-line value in a pdf.
I’m trying via regex.
Can you help me?
the values to be captured in this case would be the line containing the word “TEST”
However, I cannot default the word “TEST” as it is dynamic.
follow the pdf
Cliente Informações Montante (MWh)
DYSNEAY POPOJ Consumo 1.438,082
Perdas (3,0%) 43,142
Período de Suprimento PROINFA 27,348
ago/21 Necessidade 1.453,876
Contratos (Take %) Montante (MWh)
ABCDETAL (150%) 1.445,964
TESTE 7,912
Total Contratos 1.453,876
neste caso, preciso capturar apenas o valor da linha “TESTE”
Thanks for the answer.
however, as the text “TEST” is dynamic, for example, it can be “TEST”
On another occasion, the text may be “HOUSE”
On another occasion, the text may be “Mobile”
the default is the value after this text, which in the example is “TEST”
As I understand it in your logic, the text “TEST” is fixed, to work.
Yoichi
(Yoichi)
4
Is there any rule to identify the target line? (for example, line just before Total etc)
Good !
the line could be, below
and above
By default.
thanks for trying to help
Gokul001
(Gokul Balaji)
6
Hi @Guilherme_Silva
Use Assign Activity
System.Text.RegularExpression.Regex.Match(Your Input variable,“\S+\n(?=Total)”).Tostring
You can Try with the below Regex condition
Hope it will work
Regards
Gokul
Yoichi
(Yoichi)
7
The following expression might be better.
System.Text.RegularExpressions.Regex.Match(yourString,".*(?=\r?\n\s*?Total)").Value
thanks guys, they both helped me !!
thank you very much
system
(system)
Closed
9
