I have a Extracted Datatable from website. Let say, Extracted datatable has 20 rows and i want to add only 10 DataRows into my New DataTable. Can i make this possible?. Can anyone help.
Yes, You can. Try below expression to read first 10 rows from given input dataTable.
newDT = inputDataTable.AsEnumerable.Take(10).CopyToDataTable
Lets suppose, i have filter conditions which filters the values from the first dataTable and it only copy the values which satisfy the condition into new datatable. How can we do that?
Buddy @VenkatDurbha
you can use add data row activity to add the filtered datarow to a datatable you want
Buddy @VenkatDurbha
newDT = inputDT.Select(“[ColumnName1] = ‘Value’ AND [ColumnName2] = ‘Value’ AND [ColumnName N] = ‘Value’…”).CopyToDataTable
And also you can use Filter DataTable activity.
or you can use filter datatable activity and make the filter you want and the output will of datatable with rows you need buddy @VenkatDurbha
I have tried using that, but didn’t worked. I have using For Each Row activity and kept “Add DataRow” activity inside it. In DataRow am using “Row” which i get from For each Row activity. But i didn’t worked.
buddy mention in array row property and not in datarow property in add data row activity buddy @VenkatDurbha
and try to use for each loop with input as datatablename.Rows and change the type argument of the for each loop as datarow, instead of using for each row loop
and in add data row property with array row, mention like this buddy {item(0),item(1),item(2)}
where item is the variable obtained from for each loop activity and item is of type datarow which can be obtained by changing the type argument of for each loop as datarow and 0,1,2 are the column index buddy
Kindly try this and let know buddy whether this works or not
were you able to get now buddy @VenkatDurbha
buddy can i see the properties of add data row activity
mention the values in arrayrow property of add data row activity buddy
like this
{item(0),item(1),item(2),…)}
where item is the variable from for each loop and 0,1,2,…are the index of the column buddy
Cheers @VenkatDurbha
No need to use Add Data Row activity and all here. just check above posts of mine and try.
If i don’t want to add specific columns and wanna to add specific rows to New DataTable, then what should i do??
I don’t want to hard code the rows, as i want add specific rows based on the filter conditions which remove the rows and will only add the rows which satisfy the condition into new DataTable.
Buddy we are not hard coding the rows here buddy
we are mentioning it as a array of row buddy, not the value
only if we mention the value explicitly like {“1”,“2”,“3”,…} it becomes hard coded
here we are passing them after validation as a array of row buddy
@VenkatDurbha
if i dont know the number of rows are there in the datatable then??.
Buddy that must be if we dont know the number of columns in a row to be passed in array row property of add data row
fine
propably that we know only then we can create a datatable buddy, we might not know the number of rows in a datatable but only when we know the columns we need we can create a datatable buddy @VenkatDurbha
if i know all the columns need to be added into the new datatable, then what should i do?
Fine, you can mention the column index of all the column in the array row value buddy
@VenkatDurbha
