Hi Team,
I want split in particular column values and update next column with new column name in same excel sheet
i am using one excel file only
I have attached image for for yours ref.
Please anyone help me out from this.
Raja G
Hi Team,
Raja G
@Raja.G
prepare a target datatable with build datatable activity - dtResult and configure the 4 datacolumns: Name, Input, Output, Test
use a for each row activity (loop over your origin datatable)
but same datatable does not have the output column, right?
Yes output column not present in datatable
So we can do it with a constructing a new datatable
However the building block will be the same:
Output = row(1).toString.Split("_"c)(1)
As an alternate add datacolumn (Name: Output) to the origin datatable
set the position within an invoke method activity and use the SetOrdinal method
Loop over the datatable and set the output within an assign activity by:
row(“Output”) = row(“Input”).toString.Split("_"c)(1)
Thanks a lot ,the code is working
@ppr ,
I am getting error like Assign Exception has been thrown by the target of an invocation
Just open a new topic for your case, so we will adress it individually. Feel free to share there with us a more info on what you have implemented so far
