How I can put an As-Is process and a To be Process together in the same task capture project?
I want to export the report and have the As-Is an To-be process in the word report, is that possible?
@Juan_Betancur
Welcome to the community
You can perform the as is steps with assisted task capture and with unassisted try to get the to be and club them
