- Open the Chrome browser and paste the link.
- Check the address bar at the end, where there will be a step number (e.g., 1).
- Capture a screenshot.
- Save the screenshot and rename it.
- Repeat the process, but this time, the step number in the address bar should change to 2.
I have around 40 to 50 steps that I need to capture screenshots for. I would really appreciate it if someone could guide me on how to implement this in UiPath.
Thank you in advance for your assistance!
@Minimouse
Try this one, it would be helpful:
- Initialize variables:
- Create an integer variable called
stepNumber
and set it to 1. This variable will keep track of the current step number.
- Create a string variable called
screenshotPath
to store the path where the screenshots will be saved.
- Open Chrome browser:
- Use the “Open Browser” activity to open the Chrome browser and navigate to the desired link.
- Capture screenshot:
- Use the “Take Screenshot” activity to capture the screenshot of the web page.
- In the “Filename” property of the activity, provide the path where you want to save the screenshot. You can use the
screenshotPath
variable and append the step number to generate a unique filename for each step.
- Increment step number:
- Use the “Assign” activity to increment the value of the
stepNumber
variable by 1.
- Repeat the process:
- Use a loop (e.g., “For Each” or “While” loop) to iterate through the desired number of steps.
- Set the loop condition based on your specific requirements (e.g., iterate until the
stepNumber
reaches the desired maximum step).
- Place steps 2-4 inside the loop to perform the actions for each step.
Hey @raja.arslankhan
Thanks for the response. but its not working for me.
@Minimouse Can you explain step 5 little bit more so i can suggest other solution
Hi Please take a look Screenshot video
@Minimouse
will check and update you
