I need read specific number dont’read text and empty cell
am beginner i don’t know function in ui path
please teach me
thank you.
please teach me
thank you.
Hello,
You can get that value as text and then use the CInt function to convert it to a number:
CInt(“1234”) will convert the text “1234” to the number 1234
you can use if condition in for each row loop
condition you can use if variable contains any numbers, go into then loop and add into list,array
Hi @alicezona,
You can use Read Range to read your Excel as DataTable and then use LINQ in an Assign to filter out what’s not numeric.
Example (assuming you only want to filter column in position 0)
dt_YourTable.AsEnumerable().Where(Function(row) Not String.IsNullOrEmpty(row(0).ToString) AndAlso Information.IsNumeric(row(0))).CopyToDataTable
FilterTable.zip (50.5 KB)
Best,
Daniela
read cell and compare the cell value with regex(0-9). if true then proceed else continue to next iteration.
thank you.
wow so great
thank you.
Great work.
Thank you
ok maybe to try
thak you
