I need read and keep specific data in red box but no read and keep text empty cell.
ps. now i use function in picture 2
please guide me am beginner rpa uipath.
Hi @alicezona
Here is the solution for your requirement
Code:
ReadSpecificExcelColumns.zip (16.9 KB)
Note: If you do not want to auto populate the column 1 value (highlighted in yellow) in following rows means , you can disable that piece of code.
Kindly check/test the given solution and close the topic by marking the solving post as 'solution’
Hope this will help you. Thank you.
