In this datatable whenever I have column1 value “4567” and column 2 value “1001” then column 3 it makes “failed” and in column 5 it make “failed adjustment”
Can you elaborate a little on the ask
a sample output would help and instead of screenshot try uploading a file
cheers
Please Upload the output file also
Hi @Swarit_Goyal
→ Read Range Workbook
Output-> dtInput
→ You can use the beow syntax in assign:
outputDT= (From row In dtInput.AsEnumerable()
Let col1 = row("Column1").ToString()
Let col2 = row("Column2").ToString()
Let col3 = If(col1 = "4567" And col2 = "1001", "failed", row("Column3").ToString())
Let col5 = If(col1 = "4567" And col2 = "1001", "failed adjustment", row("Column5").ToString())
Select dtInput.Clone().Rows.Add(col1, col2, col3, row("Column4"), col5)).CopyToDataTable()
outputDT is of DataType System.Data.DataTable
→ Write Range Workbook → outputDT
Hope it helps!!
hey @Swarit_Goyal
Use for each activity:
-> if `CurrentRow("Column1").ToString = "4567" AndAlso CurrentRow("Column2").ToString = "1001"`
Then
To: `CurrentRow("Column3")`
Value: `"failed"`
To: `CurrentRow("Column5")`
Value: `"failed adjustment"`
Along with then:
sounds like a column values update on a subset of rows.
Have a look here:
and have an overview on the different options for it.
Here is also discussed the
- LINQ datatable reconstruction approach
- the recommendation to work on filtered subset
