Help me solve this problem!
how to disable copy paste in a pdf file in UiPath so that encryption is not needed but copy paste should not be accessible kindly share the solution to do it!
Hi ,
I am not very sure this possible with UiPath or not. But you can set password to pdf using UiPath.
Regards
Hi @Kancharla_Mahija
It’s not possible to do it in UiPath it will work in Adobe Acrobat Reader applications only.
You can encrypt with Password. You can read the encrypt password pdf’s too in UiPath. But diabling copy paste option is not possible.
Hope it helps!!
My requirement is to disable copy paste functionality itself
ok! my requirement is not that
Your requirement is to disable the copy paste function in pdf files right,
It’s not possible in UiPath there is no activities for this, check the below thread for better understanding,
Hope you understand!! @Kancharla_Mahija
Yeah got it! thank you for the info
It’s my pleasure… @Kancharla_Mahija
Happy Automation!!
