Hi
My Condition is a Integer.
One of my case is for the integer > 5. But when I enter >5, I get error that is not valid for int32.
Thank you
Hi
Thank you
Hi ksrinu070184,
Thanks for the reply. To clarify, I am using a flow switch, not switch statement.
2ndly, I have many cases.
integer=1
integer=2
integer > 5
So I can’t use boolean for argument.
Thank you
In this case You can use a IF condition like
Assign a variable as Status
If Integer = 1 then assign Status = 1 else If Integer = 2 then assign Status = 2
In this way you can try
Mark as solution if this helps
Thanks
Hi
Sorry, I don’t understand. I just want to know how to have a case with integer >5 in Flow Switch.
Thank you
Hi
Thank for the image.
But the Flow Decision only decide if int222 is > 5 or not. But what about when “int222”=0
int222=1
int222=2
I want cases for these too.
Thank you
Hi
Beside flow switch, are thee other activity I can use for
Case =0
Case =1
Case =2
Case >5
Thank you
You have add another condition and make status to 3,4 and so on
According that you can configure your flow switch
Thanks
Can you try the following?
First, set the following expression to Condition property of FlowSwitch activity.
Convert.ToInt32(intVar=0)+(Convert.ToInt32(intVar=1)<<1)+(Convert.ToInt32(intVar=2)<<2)+(Convert.ToInt32(intVar>5)<<3)
This means…
If intVar=0, it returns 1,
If intVar=1, it returns 2,
if IntVar=2, it returns 4,
if intVar>5, it returns 8,
if others, it returns 0,
So, you can achieve it, if set activities as the following image.
