Hi everyone,
My requirement is i have two excel
1.both has common columns “Emp Id”
2.i need to compare dt1 with dt2 with “emp id” and filter out only matched “emp Id” rows from dt1
Thanks in advance
Hi everyone,
Thanks in advance
Hi @kavya.s16 ,
For a simple check, could you try using the Join Datatables Activity with Join Type as Inner Join ?
We could then keep only the columns of the DT1 in the resultant datatable using the DefaultView.ToTable() method.
Let us know if it works out for your case.
@supermanPunch Hi , i tried inner join but it includes both dt1 and dt2 whereas i need only dt1 matches rows , how to use that defaultview.toTable() method?
Use the Expression like below in an Assign
Statement:
OutputDT = OutputDT.DefaultView.ToTable(false,DT1.Columns.Cast(Of DataColumn).Select(Function(x)x.ColumnName.ToString).ToArray)
Here, OutputDT
is result from Join Datatables
Activity, DT1
is the datatable whose columns you would want to preserve.
Let us know if it doesn’t work as expected.
